John
Wouldnt disagree the starter kit is good value
Id however consider a dualtec for the garage.
MOst of the basic panels will do as you need and the accenta is flexible for its price range.
You might want to consider the metal or the poly version as the compact is a small unit with limited space inside the panel
James
  • 1 month later...
I do agree, the ADE Accenta G4 is a brilliant low cost but robust unit too. I am 15 and I have one of the G4's with the LCD keypad for my home project and if it works fine. Really easy to programme, just need to remember the system flags as they caused confusion with me lol!
You'll be fine. Just make sure you read the manuals properly first. It has out of the box default codes so you dont have problems with programming.
I do reccommend this panel!
Ravis94
