November 2, 201510 yr Hi, I have a Honeywell Galaxy 3 48 panel running V5.50 firmware. I've seen firmware for the Dimension 48 @ V6.79. Are these 2 panels the same and can I upgrade my panel to V6.79 firmware or are there hardware difference that cap my firmware @ V5.55? I always thought they were the same panel just with different firmware but after looking though info I'm no longer sure as to the compatibility. If I can upgrade, I'll purhcase the SPI key from security warehouse but will need some instructions on ow to perform the update. Thanks
November 2, 201510 yr no the g3 and the dimension are different pcb's. Ive never tried flashing dimension firmware onto a g3.
November 3, 201510 yr Author Thanks. Is the G3 the older panel and are there any compatible Ethernet modules and C079-2 rf portals available for the G3?
November 3, 201510 yr You cannot install Dimension firmware onto the G3 PCB. The Dimension has different circuitry than the older G3-48. The SPI will not allow the flash to be added. You will need to swap out the PCB. The E080-2, E080-4 and LCE-01 are compatible with the G3, but Honeywell phone apps will not work, only selfmon apps. The Honeywell apps only work with the Dimension and Flex panels. Also, the RF portals do not work with G3, you need the Dimension with the latest firmware for that to work. You can use the older RF RIO with the G3, but to be honest, you're best to just upgrade to the Dimension. The latest firmware for your G3 is V5.55 The latest firmware for the Dimension is now 6.92 which supports output control via apps (but only with GD-48 and GD-96 due to firmware bugs with the bigger 264 and 520 panels).
November 6, 201510 yr Author Great info thanks. Is the upgrade a straight pcb swap into the existing enclosure or do I need the entire new panel? Where would have a GD48 board available for sale?
November 6, 201510 yr It's a straight swap. The enclosure and PSU is the same. The latest Dimension comes with a back wall tamper switch, but that's for regulations and doesn't matter if you're self install. They sell PCB's on this site, but almost £200 for a Dimension 48. I don't think they will let me post pointers to anywhere else.
November 7, 201510 yr No worries. I don't want to undermine SW. I promote it as the best/lowest cost online e-tailer for security equipment. It would have been second user equipment that I would have pointed to anyway, and that's not for everyone...
November 8, 201510 yr Author I don't mind used kit, it's for home so just need to swap the pcb. I'll try and dig out your sale.
