Secware2 Posted August 3, 2015 Posted August 3, 2015 I'm currently running Ubuntu Linux on my laptop and would like to know which security cameras or kits are compatible with my system. I'm looking at both wired and wireless options. I want a 4 channel system that I can monitor from a web browser or "zonealarm." The control unit or transceiver should be able to connect to my laptop through usb or WiFi. Quote
Secware_Tech6 Posted August 3, 2015 Posted August 3, 2015 I don't know of a dvr that does. Most units require activex or apple safari plugins for browser use or use windows applications. You may be able to use WINE on Ubuntu but it isn't supported Quote
johnw54321 Posted August 4, 2015 Posted August 4, 2015 I don't know of a dvr that does. Most units require activex or apple safari plugins for browser use or use windows applications. You may be able to use WINE on Ubuntu but it isn't supported I inted to run the system from my laptop and use it as the DVR, which zonealarm is made for. Quote
Secware_Tech6 Posted August 4, 2015 Posted August 4, 2015 Do you mean zoneminder? You are going to run your laptop 247 as a dvr? Quote
