Secware2 Posted May 7, 2015 Posted May 7, 2015 i ordered a Texecom alarm R8+ in 2010. I setup the alarm last year.i got some PIR petwise frmo texecom.Well, i have false alarm during the night 1x / each month in the room where there is a sofa. I have 4 cats. I guess, they jump from the sofa.Do you know a trick to decrease the sensitivity ? or there is another solution / PIR to avoid those alarms to buy ? Quote
Secware_Tech6 Posted May 10, 2015 Posted May 10, 2015 Id advise a siemens eline dt in that situation. Its the best pet sensor I've personally tested. But the only 200% way is to use perimeter protection, ie vibs and contacts Quote
