Hello
I installed a month ago scantronic 9651 the alarm goes in to fault mode
When i read the log it states            'bad checksum'    could you tell me what this , also it sometimes come up plug by communications is out , but i check the sd2 DIALLER it is functioning, line is ok
If the same line is on a non filtered dsl telephone line could this interfere ???
Thanks
Mr Patel
Hello
Thanks
Mr Patel
No a non filtered line could not cause this. Id suggest you have a faulty panel. If you havnt done so please contact technical and they will authorise an RMA number so we can swap this panel for you.
Tech Support
