Secware_Tech6 Posted August 9, 2009 Posted August 9, 2009 Can you please tell me which one of these two products, GJD Mini Opal External PIR or Opal XL 12V PIR 35 m works with an older version of a GJD controller - it has a 6 wire configuration. The old ones - have disintegrated lenses due to UV light - they have GJD on the inside of the housings and they have a pan-tilt PIR but no model number if this helps. I've looked on your site regarding the new types of controllers which are very similar to the type that have been installed. Once I know if either are compatible I will need to order. Quote
Secware_Tech6 Posted August 9, 2009 Author Posted August 9, 2009 Hi Duncan Both of these units will be ok with the older controller Hope this answers your question Regards Elaine Quote
