Could you please advise on suitable outdoor sensors to control outdoor security lights (already installed).
I require 3 corner mounted sensors with a minimum range of 12 mtrs and 1 standard mount with a range of 20m (if possible). All will be exposed to the weather and all should be in black.
I live in the countryside and do get deer & foxes in the garden, are these likely to trigger the sensors?
Regards, puzzled
Yes standard sensors will be triggered by cats, foxes etc.
However risco make a unit called the watchout that is designed to ignore cats etc. However deer is a different matter. The target size and density is similar to a person.
If you have deer then a PIR is not a viable solution IMO. You should be looking at active beams.
Support
Thank you for the info. Please excude my ignorance, but what does IMO mean?
Also can you give some examples of suitable active beam equipment?
Regards
