Secware Posted January 6, 2014 Posted January 6, 2014 texecom odyssey bell box appears to be faulty, I have checked the voltages and the tamper circuit but the bell is active constantly. Is there anything that can be done about this? Quote
Secware Posted January 7, 2014 Author Posted January 7, 2014 The sounder requires a negative trigger to operate. Is the panel giving out a negative trigger? Is the control panel programmed as scb? Quote
admin Posted January 7, 2014 Posted January 7, 2014 To be sure then 1 ensure sounder is in SAB mode 2 connect only hold off voltages 3 ensure all tamper switches are closed 4 ensure high security bell is not enabled Quote
