t.wf Posted May 25, 2009 Posted May 25, 2009 Hi all, I have a Texecom Premier 48, to which I am trying to use the Wintex software to program. I am attempting to use my PC modem to connect to the 2400 com modem installed on the panel. However I can not get a connection with my PC to the panel. Has anybody had issues when trying to do this? Thanks. Quote
Secware_Tech6 Posted May 25, 2009 Posted May 25, 2009 Not all modems are compatible. But usually they should be ok. Often its a configuration error at the panel end. Is the panel answering the call correctly? Do you have broadband filters on both ends etc. Quote
