Secware Posted November 20, 2013 Posted November 20, 2013 Hi - I would like to purchase two of the item below but I need to ensure that they are compatible with my DMX lighting system which is made by Pharos Controls. It has a remote input output processor which can handle either a high or low signal (NC/NO).Texecom Prestige External TD Outdoor Motion Sensor Black AFQ-0001 Quote
Secware Posted November 22, 2013 Author Posted November 22, 2013 Having checked with Texecom their technical have responded the below: "That product would be fine for the situation. It simply needs a 12v supply and each time it is active will give an open/closed circuit on the alarm terminals." Quote
admin Posted November 24, 2013 Posted November 24, 2013 Unfortunately we don't support that controller so it may. But if the unit accepts voltage input then it should Quote
