Secware Posted November 15, 2013 Posted November 15, 2013 i have a garage , the garage is not connected to the mainbuilding.can i use a visonic remote to operate the garagedoor ?the door is operated by remote today and it has a switch inside the garage , one push opens, another push close the garagedoor.if this is possible, wich remote do i have to use and what do i connect the garageswitch to Quote
admin Posted November 15, 2013 Posted November 15, 2013 you could use a visonic stand alone reciever and connect the relay to the push button, but this will probably involve modifying the switch as id doubt it has external connections, then you can program a fob transmitter into the reciever Quote
