novice Posted May 21, 2009 Posted May 21, 2009 Hi everyone. I have been reading a lot of your helpful comments on various wireless alarms[ in particular]. as you will have gathered by by nom de plume I do not know a lot about these items. My questions are, in the scantronic range is the 703r contact transmitter for hard wiring in garage block to signal back to main panel in residence by wireless and are the 2 wired relay outputs suitable for external sounders [ sab]or do I have to use a conversion panel as on sapphire website. john Quote
Secware_Tech6 Posted May 21, 2009 Posted May 21, 2009 if you want to send signals from rf devices, weather they be contacts, pirs etc you need some form of reciever. You can either use a stand alone reciever which is designed to be wired into a control panel or a integrated reciever. You will need some form of panel etc, else how will you arm/disarm it, silence it etc. Support Quote
novice Posted May 22, 2009 Author Posted May 22, 2009 Hi Secware Tech6. Sorrry if I did not ask the right question. If I install the Homelink 75 panel in the main house as a complete system. And I need to alarm the remote garage block . My main requirement is to hardwire in the garage block and then radio signals back to the 75 panel. With regard to the second question Re the hardwired sounders [sab] do I also need a converter.to change the signals at the panel. If I get this understood then I can order all the correct kit. Thanking you for your patience. John. Quote
Secware_Tech6 Posted May 22, 2009 Posted May 22, 2009 i see yes you need a uniersal transmitter to send your hardwired (door conatcts i assume) to the homelink. You can use any std hardwired sounder with the homelink. Quote
novice Posted May 22, 2009 Author Posted May 22, 2009 Hi Secware Tech6 Thank you for you quick reply that is just what i wanted to read. I will be ordering all the necessary items today. Yours sincerely John. Quote
