Secware Posted June 10, 2013 Posted June 10, 2013 I am unable to enrol the KP-141 PG2(June2013) to the Power Master 30 alarm system(Nov2012): - Full enrolment procedure: I select the * key on the keypad until the LED turns on and then release the * key. The Power Master 30 alarm system (i.e. Add New Device -> Enrol Now) indicates on its display, "Incompatible Device". - Pre-enrolment procedure: I enter the Id of the device into the Power Master 30 alarm system and it is accepted (i.e. Add New Device -> Enter Id). However, the Power Master 30 alarm system indicates that the keypad cannot be networked. Quote
Secware Posted June 19, 2013 Author Posted June 19, 2013 It sounds like the Kp-141 you are trying to use has the wrong region code... On the back of the unit it should have a number in this format - (868-#:###) with the #'s being numbers, I need to know what that code is please. Quote
