Accenta G4
kaibil
Just installed the Accenta G4 panel and all worked well.
a few days later a fault occured to the entry/exit.
Problem is break to the pair of contact wire. Replace with the spare and makes and break but the problem is the panel does
not register open/close of the contact but ok with the multimeter.
Another factor that I can assume is new carpet was fitted and wonder if the fitter damaged the cable which I think would be most likely as
it was all working fine before the carpet was fitted. No short between contact wire and tamper wire. Any help would be grateful.
I will run a temp cable this weekend and see what happens.
I think you have answered your own question, that is to run a temporary cable.
  • 1 month later...
