securitywarehouse Posted March 16, 2011 Posted March 16, 2011 have an IP camera that I would like to alarm via a PIR. The Camera has I/O contacts & the input contacts create an alarm when shorted - the contacts are rated at 1amp @ 28v. Please suggest a PIR which will work - normally open contacts I assume & preferably battery powered. Quote
securitywarehouse Posted October 28, 2011 Author Posted October 28, 2011 Is this for internal or external fitting?? Quote
Secware_Tech6 Posted November 1, 2011 Posted November 1, 2011 You wont find a sensor that is battery powered with clean contacts. The relay would flatten the battery in no time. Usually on IP cameras the alarm input is configurable as N/O or N/C. I would suggest a 12v sensor such as the Voltek AUtoswitch but this will require a 12v Power supply. How are you powering the camera? http://www.securitywarehouse.co.uk/catalog/voltek-autoswitch-p-2453.html Quote
