I am replacing a Karisma plus alarm system in a large house. Unfortunately this randomly goes off & is especially susceptible to fluorescent lights.
Requirements for new system:-
Be able to identify all items individually and have them displayed with name on RKP eg kitchen window, front door. House has several loops of 4 core (unscreened) cable so can't put items on individual wiring.
No windows = 17
no doors = 3
no PIRs = 6
no fire detectors = 2
no RKPs = 3
System should have dialer + speech module or GSM
Hopefully system can be set to detect two events before alarming.
  • 2 weeks later...
Hi , have you had the system serviced recently? , if it is still working then there may be a reason why it is giving trouble , and that could be interference from a faulty appliance , and changing the panel may not cure this.
I would at least replace the battery.
Thanks,
I have always had problems with alarm since installation. I have fitted filters on mains input with no effect. Even when alarm is un-armed it will go off with tamper problems. Switching one particular fluorescent light more or less guaranteed to set it off. I now use electronics starters and this gets over the problem. I have also replaced some of the wiring with screened cable and this has helped greatly. Wiring seems to pick up some interference.
Replaced battery recently. Alarm has always had a problem with power outages, causing keypads to lock up. It has to be completely powered down (mains & battery disconnected) to reset main board. I suspect there may have been a later version of the panel which worked better, judging from reaction I got from ADE when I contacted them once.
I didn't realise reed switches were so unreliable. I have two go fault recently. Not good for relations with neighbours.
I am looking at Texecom Premier alarm with ID+ support. At least might be able to set two triggers before it goes off.
