[Ticket Question] Help with the Accenta Gen4
securitywarehouse
I am planning to replace an old intruder alarm system with all new equipment. The only problem I can foresee is the space available for the control panel (fitted in a meter cupboard).
The existing panel is a GARTEC (h175xw210xd70).
An ACCENTA MINI GEN4 (h200xw253xd55) will fit in the space available but there will be little room (approx 20mm) above and below the panel.
My question is: How does the front cover of the panel open and/or how is it removed? Does it hinge (top & bottom) and will I have enough room to open/remove it?
Thanks for the reply.
Heat build up is not an issue. The cupboard is a large one, the only space
restriction is directly above and below where the Panel is sited.
This is because there are other fittings above and below the panel which
could interfere with the opening of the front cover if it is
hinged.....hence my original question.
So, does the front cover need to hinge to open or can it be completely
removed?
I await your reply so I can place my order.
Hi , the lid does hinge , at the top and bottom , you undo the screws , lift the top lid approx 90 degrees then pull forward to remove , same for bottom.I'm not sure 20m will surfice..could only suggest trying it, but I dont know of a smaller end station.
