securitywarehouse Posted December 13, 2010 Share Posted December 13, 2010 I had scantronic 9800 alarm system installed 20 years ago, working fine, my key pad box cover is broken which covers all the key pad, there is Scantronic 9827 key pad only which is on your website it says it is now obsolete, will this key pad is same as my 9800 key pad with the cover and work same as old key pad? If it is I would like to order ASAP. Quote Link to comment Share on other sites More sharing options...
accounts3 Posted December 13, 2010 Share Posted December 13, 2010 Do you need the cover, could you just remove this flap, if the 9827 is obsolete and we are out of stock then we would not be able to supply that unit Quote Link to comment Share on other sites More sharing options...
