[Ticket Question] Help with an Ody 1E
securitywarehouse
Hi, I had an alarm system and we started having problems with our bell box (kept going off because it was too close to the boiler flue). I decided to replace the bell box and bought a Texecom Odyssey 1E. We've fitted the bellbox but it won't seem to work with my existing system. I'm not sure but it may be that its not compatable with the panel/key pad. I could do with knowing what panel/keypad would work with this bell box, how much they cost and whether you stock such an item. Thanks
Link to comment
Share on other sites
thanks for the reply. Your reply was very kind re most wired alarm systems and bell boxes being compatable and that its just the wiring that needs sorting. My alarm system is an 'ALTO' AL2163 with built in communicator outputs and remote LED keypad. I've read that direct from the front of the engineering information! The bellbox is (as I've already mentioned) a Texecom Odyssey 1E. Thanks for any help you can give with sorting this problem. David
Link to comment
