securitywarehouse Posted November 8, 2010 Posted November 8, 2010 I have purchase from Security Warehouse an ADE Honeywell Easy Set Unit with an ADE Honeywell Accenta Metal Gen 4. The instructions for the Easy Set provide Wiring Details for connection to a G3 and an Accenta 8 Panel, but there is no wiring and program changes for a Gen 4. How is the wiring configured and what program changes are necessary. Our Reference Secware 3 sent 19.45 on the 5th of November. Quote
accounts3 Posted November 16, 2010 Posted November 16, 2010 Thank you, have checked order, and will ask somone a lot more technical than me to answer your query Anne Quote
FastCar Posted November 16, 2010 Posted November 16, 2010 The Simple Set unit connects exactly as a second keypad would , and no extra programming is necessary.The programming is only required when integrating into a different manufacturers panel using a zone as keyswitch. Quote
