securitywarehouse Posted September 27, 2010 Share Posted September 27, 2010 I installed a system a year ago which I purchased from you and it seems to have developed a fault. Initially when a walk test was done it wouldnt identify some of the zones and then removed the cover from the unit and I cannot get rid of the cover tamper warning so cannot set the system. Do you think the control unit has gone U/S. steve Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted September 28, 2010 Share Posted September 28, 2010 Possible but i doubt it. Id say you have an unrestored tamper somewhere. check all the tamper inputs including panel, keypad and sounder etc. Quote Link to comment Share on other sites More sharing options...
Stainlesteve Posted September 28, 2010 Share Posted September 28, 2010 Thanks very much, I have managed to remove the tamper fault but the unit still doesn't want to do a walk test, I have been wondering how to do a complete reset? Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted September 29, 2010 Share Posted September 29, 2010 What is dispalyed on the panel. Your install manual will tell you haw to factory reset it if needed, obviously we cant say on a public forum. But i doubt a reset will help unless you have programmed something wrong. Quote Link to comment Share on other sites More sharing options...
