AMuir Posted October 9, 2008 Posted October 9, 2008 My existing panel was faulty so I puchased a Risco Gartec 490x from you. I liked it beacuse it is hybrid wireless and we are having an extension built, which will make it easy to add additional movement detectors. The control panel and keypad are installed and work fine apart from one problem. I get a warning - off chg volts high / battery/fuse fault - it takes a about 30 minutes after exiting the engineer mode for the fault to register. Its a new battery (again purchased from you) and the fuses are all Ok - any ideas what I have done wrong. Also given that I am not a registered installer will Risco technical help talk to me or am I on my own. regards Quote
Secware_Tech6 Posted October 13, 2008 Posted October 13, 2008 If you have a look in your manual there is a setting to adjust when the panel will report low volts. Id suggest you have this too high. Also check your charging voltages.Let us know what your charging voltage is, and your system voltage / current in day. SUpport Quote
