September 3, 201016 yr have purchased a Honeywell DT7450UK2 motion sensor for use in a conservatory and having received it am unsure of its compatability and wiring requirements. My security system is 12v however the wiring information states 24vdc for tamper and alarm. Please advise.
September 23, 201015 yr that is the maximum voltage, as they are switches the voltage is irrelevant in your case
