securitywarehouse Posted September 2, 2010 Posted September 2, 2010 Proposed Gargage Alarm System Before placing a package order I just need to confirm that the Scantronic 9651EN-43 Panel will support 2 x remote extension speakers. I note it has 3 fully programmable outputs, I need a volt free relay / contact output (N/C healthy) Open Circuit on alarm condition for remote signalling to an existing Scantronic 9752 panel located in the house (this will then represent a seperate zone alarm, just like say a PIR in alarm condition going from N/C to open circuit) - please could you advise, order ready to go. Quote
Secware_Tech6 Posted September 23, 2010 Posted September 23, 2010 this panel does not have a built in relay but you can an an external relay to one of the voltage outputs. Yes it will run upto an 8 Ohm load. SO that could be 2 x 16 Ohm speakers in parralel or 4 x 16 ohms in series and paralel etc Quote
