securitywarehouse Posted August 31, 2010 Posted August 31, 2010 Hi I intend to upgrade my home security,the system,has a Veritas R8 panel and 8 PIR(IFSAC MQ1510)zones along with 2x RKP there have been many false alarms, due to, I think the poor PIR's, I was looking at installing up to 14 zones (2 door contacts, 8 Pir, 2 dual tech PIR,(orangery & Kitchen) 2 dual tech PIR (detached Garage)and 3 RKP. could you recommend the best control panel, RkP and PIR's I need to have the garage, armed when the house is not and also to have the 2 PIR's on the first floor omittable. Is it possible when there are any alarm activations to call a phone number. I have been looking at the Gardex 595 & GT490, and Pyronix KX PIR would these be suitable or can you recommend others Quote
Secware_Tech6 Posted September 23, 2010 Posted September 23, 2010 id recommend a honeywell G2-20 / 44 with expansion. Pirs id recommend optex and honeywell as a brand. But actual sensors depend on the environment. If you want it to call someone then you either need a voice dialler or some sort of prefessional communicator. Quote
