August 31, 201015 yr Hi I am looking for an alarm for a workshop/shed, 1 opening window, 1 fixed window and double doors. I have used Scantronic previously and therefore would like the following:- Scantronic 9448, with 2 contact switches, a glass break sensor, Elmdene INT400 and a battery. (I have avoided PIR\\\'s because of false alarms) Could you advise if this is suitable or are there better options, please advise battery type for above.
September 23, 201015 yr you will have to use a 2.1-2.3 A/h battery in that panel as that is all it will accept. I would advise you back up your glassbreak sensor with some trap protection. Maybe a dualtec movement detector? But yes what you have is a workable config
