admin
Administrators-
Posts
11 -
Joined
Last visited
Days Won
1
Content Type
Profiles
Forums
Events
Everything posted by admin
No. If your an installer id recommend the hkc 1070 and using its app from the app store to do this. Or the galaxy flex and the galaxy app. https://itunes.apple.com/gb/app/gx-remote-control/id790084713?mt=8
[Ticket Question]Ventcroft Classic With Veritas Compact 8
admin replied to Secware's topic in Intruder Alarms
Id be suprised to have 2 in a row. It may be worth us checking if there is a batch fault. Every other part of the bell is functioning? If it is and you have connected 0v to the strobe trigger and verfied there is voltage there then id say you must have. Thats why i think we should check the manufacturer isnt aware of a batch issue -
Replace Basic Viper Gl With Glx(With Contacts) - Straight Swap?
admin replied to mbsproperty's topic in Intruder Alarms
Yes unless they are very old -
[Ticket Question] Accenta Mini & Elmdene 7422 Wiring
H- = Hold off - = A H+ = Hold off + = D+ BAT- = for the internal battery FAULT = not used on this panel REM TST = not used ENG = not used TR = Tamper Return = T TS = Not used R- = Bell trigger = B- ST- = Strobe Negative = Strobe - -
You could consider a louder speaker (ie 16 Ohm) ind fit that outside the cupboard
H- = Hold off - H+ = Hold off + BAT- = for the internal battery FAULT = not used on this panel REM TST = not used ENG = not used TR = Tamper Return TS = Not used R- = Bell trigger ST- = Strobe Negative -
If you connect just 12v and 0v to the strobe on the bell does it function then. Also just verify you dont have a terminal marked stb+ -
How many codes do you have programmed in the system? Have you tried using your high level code? Have you tested all user codes programmed in? I can only suggest a factory default and reprogram. I cannot see it can be a faulty module as it appears to be working. Id also suggest putting the sim in a phone and checking it can recieve sms messages correctly
The config is held in the main panel so no programming changes will be needed
id assume you havnt enabled the digi unit. also make sure premium calls are allowed on the line. it needs to call the chc to pick up the numbers for sms servers. as a side note avoid sms over pstn unless your using a subscription service
How Do You Stop The Led From Flashing On A Viper Glx?
admin replied to winton's topic in Intruder Alarms
power the glx from an output progged as viper reset -
[Ticket Question] Honeywell Viper Glx Led Not Working?
connect the vr input and program the panel to reset on disarm -
Sorry we cant support pro product in a diy way. Ask your installer to contact us
id suggest your battery is either gone, charged wrong polarity or leads in the wrong positions
Confusion Re Wiring When Replacing Racal Guardall Rlc1 Control Unit
admin replied to alshookup's topic in Security Lighting
i doubt the existing sensors will work with a gjd controller but there should be as a minimum a 4 core lv cable going to existing detectors. gjd detectors need 4 cores (power, detection and light level signals) to function. do you / did you have a multi controller system? -
No that unit is for the older 1 way panels
It could be done but as above will not work on its own perfectly. Might be better to say what your trying to achieve?
AFAIK no it needs a backend that you connect to via the arc etc
The PIR element of any DT will be more unstable than a pir only usually. They are designed to work with the Microwave. Whats the reason for disabling the mw element. Howeber the fx50 is a good detector
I would suggest a firmware update on the panel.
You will get better performance from a honeywell galaxy Flex and the selmon app. Just use an ethernet module and connect to your broadband
I dont believe so, but texecom is not my own preferred product. The honeywell Flex can do gsm calling of pstn recievers but you may be better of using it in gprs mode and reporting via ip. Mobile networks are not designed for data over voice calls. You will need a gsm module etc http://www.securitywarehouse.co.uk/catalog/index.php?main_page=product_info&products_id=2491
AFAIK no one makes a dect dialler, however you can get dect converters. However do you want to do this as in the even of a power failure you will loose your dect base station
Bell-............BELL Bell HO............12v- Strobe +............12v+ Strove - ...........STB SAB Tamper........T The cp8 is a very basic panel and does not iirc have an output suitable
It will be listed in your manual. We cannot put that in the public support forums for security reasons.
