I have a new optima accenta gen 4 panel and an existing pyronix belle box. I have wiring diagrams for both but need help as to which wires go where!
The wires are as follows:-
PANEL - T = NEGATIVE (-VE) TAMPER RETURN
            A = NEGATIVE (-VE) SUPPLY (OV)
            D = POSITIVE (+VE) SUPPLY (12V)
            B = NEGATIVE (-VE) SOUNDER TRIGGER
BOX -    B- = NEGATIVE (-)
            B+ = POSITIVE (+)
            BA = BELL TRIGGER TERMINAL
            STB = STROBE TRIGGER TERMINAL
            BT = TAMPER RETURN
            TF = TAMPER FEED
Any ideas please? Thanks in advance
            B+ = POSITIVE (+)
            BT = TAMPER RETURN
            TF = TAMPER FEED
Bell              Panel
BT              T
B-              A
B+              D
BA              B
You will also have a strobe output on your panel connect strobe - on the panel to STB
You will also need to link Tamper feed to B- in the bell.
Support
Just wanted to say thankyou for your help and prompt reply. Everything seems to be in working order.  :)
Tp
