August 15, 201015 yr Which hardwired detectors (PIR-movement detector, magnetic contact, siren, smoke detector and siren) are compatible with the powermax+ unit?
August 17, 201015 yr ANy of the detectors offering form c relay (ie Normally Closed loops) Pretty much any detector has this as std.
