August 4, 201016 yr Hi, Will I have any compatibility problems if I buy the controlpanel (powermax+ or powermax pro) from sweden and all the sensors from UK? I would like to have the speech and text in swedish. Could I even mix my setup with sensors from sweden and UK? Does any of the powermax(+/pro/complete) controlpanels support swedish language? regards Olof
August 5, 201016 yr The sensors are the same worldwide apart from the frequencies. As long as your panel is 868 then a visonic 868MHz will be fine. The language is not user programmable.
