rocky Posted July 29, 2010 Posted July 29, 2010 Hello all, appreciate some help here, i have 4 pir sensors and a ADE Accenta Mini Gen4 panel, how should i wire the pir sensors in series? or should i wire each pir back to the panel? thanks for the advise! Quote
pedders Posted July 29, 2010 Posted July 29, 2010 Wire them all back separately, you will have more flexibility when programming then, If you wired them all in series then they will all have to be one circuit/zone type. Quote
rocky Posted July 29, 2010 Author Posted July 29, 2010 ok great so each pir will be in a separat zone if i wire each one separate? Quote
Secware_Tech6 Posted July 30, 2010 Posted July 30, 2010 yes. It's best imho to have only a device per zone. This will then allow easy identification of the device that alarmed etc. You will wire the circuit pair ie zone 2 to the alarm pair in the detector. Quote
rocky Posted August 22, 2010 Author Posted August 22, 2010 do i have to use the tamper wires? everywhere i read it says the alarm & tamper should be in series? or can i wire each tamper wire straight back to the panel Quote
Secware_Tech6 Posted September 23, 2010 Posted September 23, 2010 you do cable them back to the panel but they need to electrically be in series on a double pole global tamper panel. Quote
