snaithmd Posted May 6, 2008 Posted May 6, 2008 Hi, wonder if anyone can help. I have a Pyronix sterling10 Panel and RKP and i am changing the bell box for a Gardtec Eurosec XS3D (the triangular one) i have wiring diagrams for both but i an unsure which wires go to where ...Could anyone enlightem me?? ...ie i.e ST- on bell box to NO on panel, TMPR on bellbox to BElLL- on panel etc.. Please help... regards//Martin. Quote
Secware_Tech6 Posted May 7, 2008 Posted May 7, 2008 Your best bet is to list what connections you have and then someone here will translate them Quote
snaithmd Posted May 7, 2008 Author Posted May 7, 2008 Hi, The Terminals on the sterling 10 Panel are as follows :-. STROBE ( NC, C, NO) Bell ( NC, C, NO) BT BELL+ BELL- The terminals for the Gardtec Eurosec XS3D are below. ST- TMPR S- 12V 0V I ave also sent your tech dept an Email but posted on here too as it might help others?? Quote
Secware_Tech6 Posted May 8, 2008 Posted May 8, 2008 Martin You will need to wire a negative from Bell- to NO on both the Strobe and the Bell relay connections/ Then use the Common on both © as the trigger. so Panel Bell Strobe C ST- Bell C S- BT TMPR Bell+ 12v BEll- 0v Quote
