1 hour ago1 hr Hoping for some advice and please note I am not an electrician I am just trying to troubleshoot a problem before calling one.I have two pairs of ax130 tn sensors operating lights in an outdoor domestic setting.My question is when I take the covers of the sensors what should I see as far as led lights are concerned. I have a sensor that has no light on it unless the beam is broken, it then turns red.The other sensors seem to have either a permanent red or green light on. Which is correct and can you suggest a way to troubleshoot the sensors to find out if I have a faulty one?Thank you in advance.
50 minutes ago50 min Best thing to do is post photos of the transmitters and recieversThe red light shows the device is activating, there will be a set of alarm contacts. these maybe C NO NC or just C and NC depending on age. This will only be on the recievers. Use a multimeter to confirm the contacts are changing states correctly
