Posted
I am looking to alarm my workshop. It consists of 3 rooms currently with plans to add another room in the future. There are 2 up and over doors, 1 standard access door and 1 double split opening door. 2 of these doors will be entry points with a keypad located close by. Only one of the rooms has a window. There is a cat flap in one of the doors for pet access. I have been looking on your website and come up with the following list of products for the system based around a Honeywell Accenta G4 Mini panel. I chose this panel because of price and expandability. Can you tell me if all the items on the list below are compatible ? Is there anything missing from the list that I need to include ? Would you recommend against this system with a different one in mind ? Any advice gratefully received.
1 x ADE Honeywell Accenta Mini Gen4 with LCD Keypad
1 x Honeywell ADE LED Keypad for Optima G3/Gen4 or Accenta G3/Gen4
1 x Secware 12v 2.2A/h Value Alarm Battery
1 x Honeywell ActiveGuard AG6 External Siren Blue. Inc White Cover
1 x SECWARE 16 Ohm Internal Speaker
3 x Honeywell Activ8 PIR - Single Channel 18m Quad Element Pet PIR
1 x SECWARE A40 5 Terminal Flush Contact
4 x SECWARE D20 Surface Contact
1 x Secware 6 core Intruder Alarm Cable
Posted
Hi: Only personal opinion bit I would'nt fit standard Pet PIR's in a Workshop, Dual Tech would be preferable & you can get PET versions of these in store. You forgot your spur switch, pattress & 0.75mm 3 core for the mains connection.
Andy @ Amman Security
Posted
Hi Andy,
Thanks for your reply. I didn't forget the spur switch, pattress & 0.75mm 3 core cable as I already have it. The Dual Tech PIR's. What benefits in the workshop would these give me over the ones I already have on the list. This is only a DIY workshop, not a business.
Thanks,
Sam
Posted
Hi: Looking at your post I thought it was a small commercial workshop you were talking about. I prefer to use Dualtechs as once set up properly they are less prone to false alarms if used in unheated & possibly damp workshops & at the end of the day they provide a higher level of protection. 1 thing you need to remember to do is to seal all cable entry holes, in your detectors to stop draught & bugs getting into the detector & causing problems. Other than that the system you chose seems pretty good.
Posted
Can you recommend any particular make / model of dual tech pir ? I think I'll go for a dual tech for the main workshop and the original listed ones for the 2 other joining rooms.
Posted
Hi Sam: I would go for either Bosch or Honeywell, but i've used the Crow-Swann detectors in the past with no problems. I find the Bosch detectors are normally very easy to set up & reliable.
