July 17, 201016 yr I have programed all pir siren contacts and tcu remote but when trying to set full or part set the tcu displays operation cancelled instead of arming any ideas please
July 19, 201016 yr Is that what the log says? sounds like a major programming problem. Might be an idea to wipe it and start again.
July 20, 201016 yr Author I have done a full reset and added only one pir as entry exit and one tcu with the same result. Do not even get the setting tone.
July 20, 201016 yr Author Pressing the full set button on the tcu remote then entering the user code. Have tried the arm twice within a minute to force arm with no joy.
July 29, 201016 yr Sorry. I missed your reply. I presume you can access and exit engineer mode without issue? Is the mains and battery ok? also is the tel line disabled or connected? James
September 30, 201016 yr Author Sorry I have taken so long to reply. The battery and mains is fine and the telephone line is connected but not enabled.
September 30, 201016 yr Do me a favour remove the detector and only have the keypad unit. It really sounds like an acked event. Either that or a faulty panel. If be surprised though. The only thing that concerns me is the unknown event in the log. Can you confirm the exact wording and events either side please. James
