pdaws1 Posted July 17, 2010 Posted July 17, 2010 I have programed all pir siren contacts and tcu remote but when trying to set full or part set the tcu displays operation cancelled instead of arming any ideas please Quote
Secware_Tech6 Posted July 17, 2010 Posted July 17, 2010 Have all devices walk tested ok? Also anything of interest in the log? Quote
Secware_Tech6 Posted July 19, 2010 Posted July 19, 2010 Is that what the log says? sounds like a major programming problem. Might be an idea to wipe it and start again. Quote
pdaws1 Posted July 20, 2010 Author Posted July 20, 2010 I have done a full reset and added only one pir as entry exit and one tcu with the same result. Do not even get the setting tone. Quote
Secware_Tech6 Posted July 20, 2010 Posted July 20, 2010 I would say that you have an uncleared alert. How are you arming it? Quote
pdaws1 Posted July 20, 2010 Author Posted July 20, 2010 Pressing the full set button on the tcu remote then entering the user code. Have tried the arm twice within a minute to force arm with no joy. Quote
Secware_Tech6 Posted July 29, 2010 Posted July 29, 2010 Sorry. I missed your reply. I presume you can access and exit engineer mode without issue? Is the mains and battery ok? also is the tel line disabled or connected? James Quote
pdaws1 Posted September 30, 2010 Author Posted September 30, 2010 Sorry I have taken so long to reply. The battery and mains is fine and the telephone line is connected but not enabled. Quote
Secware_Tech6 Posted September 30, 2010 Posted September 30, 2010 Do me a favour remove the detector and only have the keypad unit. It really sounds like an acked event. Either that or a faulty panel. If be surprised though. The only thing that concerns me is the unknown event in the log. Can you confirm the exact wording and events either side please. James Quote
