secware3 Posted January 20, 2025 Posted January 20, 2025 How many PCs can I put the software on? Quote
secware3 Posted January 20, 2025 Author Posted January 20, 2025 Hi This kind of depends on intended use. If it's for engineers to install on their laptop and connect directly to panels onsite then it doesn't matter, can be installed on as many machines as you want. If you are looking to setup a small support team for instance with everybody having remote access to the panels then you need R057 which needs a dongle per machine (including the server). You can install that on as many machines as you have dongles for. Quote
