secware3 Posted January 14, 2025 Posted January 14, 2025 please advise me of the differences between an Optex AX 70-TN and a Optex SL 200QDP. The proposed location is no more than 20 metres. Does the more expensive unit have a technical advantage? Quote
secware3 Posted January 14, 2025 Author Posted January 14, 2025 Optex AX 70-TN has twin beams 20m range, single channel detector. and a Optex SL 200QDP has quad beams with range if 60m, 4 selectable channels and adjustable beam power Quote
