secware3 Posted September 20, 2024 Posted September 20, 2024 https://www.securitywarehouse.co.uk/catalog/intruder-alarm-equipment-c-36/remote-signalling-c-36_57/eaton-scantronic-adapter-board-p-6480.html ------------------------------------------------------ I have an older i-ON40 Scantronics alarm (Cooper Security Limited) which I would like to reconfigure to enable remote access. However I haven't found any online information that can confirm if this older model is compatible with the remote App. It is currently running firmware version 4.04.17. Is the current firmware compatible with any remote Apps that are available? If not is it possible to upgrade the firmware? Which WIFI module would be required? COM-DATA-WIFI or COM-DATA-4G-SD (It has the older style accessory mount so would also need the adapter module (COM-ADPT-02)) If there are no compatible Apps, would COM-DATA-WIFI work with my system - this would at least allow me to access the system via its onboard webserver. Many thanks Quote
secware3 Posted September 20, 2024 Author Posted September 20, 2024 Answers below regarding an i-on40 V4.04.17: Is the current firmware compatible with any remote Apps that are available? No . The panel does not support App control. If not is it possible to upgrade the firmware? No . The panel is obsolete and does not support app control, regardless of software version. Which WIFI module would be required? COM-DATA-WIFI or COM-DATA-4G-SD (It has the older style accessory mount so would also need the adapter module (COM-ADPT-02)) The panel does not support either the COM-DATA-WIFI or COM-DATA-4G-SD If there are no compatible Apps, would COM-DATA-WIFI work with my system - this would at least allow me to access the system via its onboard webserver. The panel does not support the COM-DATA-WIFI. An upgraded panel would be required. The closest match is an i-on40H+ . This has app control and can support the COM-DATA-WIFI and COM-DATA-4G-SD plug on units. Eaton 40 Zone Hybrid Panel with KEY-KPZ Keypad [I-ON40H-KPZ] - £247.94 : | Best Price Promise | Security Warehouse Professional products Kind Regards, Security Warehouse Support Quote
