HI I just installed a Risco WisDom panel and was wondering how to wire a Gardtec eusosec xs7 Bellbox to it. A wiring diagram would be very helpful if anyone can help. The panel comes with 2.2k resistors , the lid tamper is fine but the bell loop fault keeps coming up, and the alarm activating does not ring the external bell. Thanks
Attached is the wiring diagram
you need to connect the tamper return from your bell to BELL TMP
Ensure you have got the holdoff supplies from the aux connectors not the bell as the bell- is switched
Thanks for replying so quick, can you tell me if I have this right
() bellbox terminal
(Tmpr ) to bell tamper with 2.2k resistor        (S-) -bell  in panel        (12V) Bell + in panel
  (0v) Com Black in panel
do I link (ST-) for strobe to S- or what terminal is for strobe on the wisdom panel.
Thanks
