Tony Posted July 10, 2024 Posted July 10, 2024 I have a 9600 alarm installed and need to relocate the keypad, problem being the keypad is on a under stairs wall and the internal bell box is directly behind the keypad on the inside of the wall, the wire between the 2 is about 3” long, can I disconnect the bell? Move the keypad and reconnect the bell, I know the tamper will go off but will it be ok to just put the code in when it does go off ? thanks Tony Quote
Secware_Tech6 Posted July 11, 2024 Posted July 11, 2024 Yes Its normal to power it down as if you cross a wire you can blow the board or a fuse. Bear in mind to the 9600 is gonna be around 30 yr old now Quote
