Changing Texecom bellbox to pyronix
TonyL
Could someone help with connection for new box please,ive cut the cables on the old lexecom box but not sure on connection for new box,I am a spark just never worked with alarms
Thanks
Tony
  • Secware_Tech6 changed the title to Changing Texecom bellbox to pyronix
12v - = Blue
12v + = Red
Bell = Black
STB = White
Im assuming the 2 connections marked as T are a voltage input and output clean switch but not sure what bell you have.
But they re the tamper return which on your old image is Yellow
But you will need (id assume) a negative tamper return, this depends on the panel connecting to.
