TonyL Posted Tuesday at 05:37 PM Share Posted Tuesday at 05:37 PM Could someone help with connection for new box please,ive cut the cables on the old lexecom box but not sure on connection for new box,I am a spark just never worked with alarms Thanks Tony Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted Tuesday at 05:58 PM Share Posted Tuesday at 05:58 PM 12v - = Blue 12v + = Red Bell = Black STB = White Im assuming the 2 connections marked as T are a voltage input and output clean switch but not sure what bell you have. But they re the tamper return which on your old image is Yellow But you will need (id assume) a negative tamper return, this depends on the panel connecting to. Quote Link to comment Share on other sites More sharing options...
TonyL Posted Tuesday at 06:01 PM Author Share Posted Tuesday at 06:01 PM This is the box I have Keypad is premier Could anyone simplify connections i.e red to- Yellow to Etc Thanks Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted Tuesday at 07:25 PM Share Posted Tuesday at 07:25 PM 1 hour ago, Secware_Tech6 said: 12v - = Blue 12v + = Red Bell = Black STB = White is pretty simplified? Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted Tuesday at 07:29 PM Share Posted Tuesday at 07:29 PM You will need to wire to the other 'T' connection to 12v- also. You do need a - tamper return Quote Link to comment Share on other sites More sharing options...
