Posted
What USB to 232 cables are people using for G2 compatibility?  It seems that my dimension USB cable will not play ball with the G2 panel.  Works fine for dimension panels and associated 232 cable, just not the G2 panel and cable.,
Thanks
John
Posted
It just stays stuck at the connecting stage, then times out.  Lights on the USB 232 kits flash after hitting connect, i guess form RSS tool requesting hand shake, then stop when it times out.  I lowered rate below 9600, still no change.  Same panel direct 232 on my older laptop (no USB) works fine.  So am looking for a known working USB cable make please.
Cheers
John
