JohnFA Posted April 21, 2024 Posted April 21, 2024 What USB to 232 cables are people using for G2 compatibility? It seems that my dimension USB cable will not play ball with the G2 panel. Works fine for dimension panels and associated 232 cable, just not the G2 panel and cable., Thanks John Quote
JohnFA Posted April 21, 2024 Author Posted April 21, 2024 It just stays stuck at the connecting stage, then times out. Lights on the USB 232 kits flash after hitting connect, i guess form RSS tool requesting hand shake, then stop when it times out. I lowered rate below 9600, still no change. Same panel direct 232 on my older laptop (no USB) works fine. So am looking for a known working USB cable make please. Cheers John Quote
Secware_Tech6 Posted April 22, 2024 Posted April 22, 2024 I use an asix based one. Id have to check with honeywell if there is official recommendation but i wouldnt be hopefull, iirc they dont support serial over usb Quote
Secware_Tech6 Posted April 22, 2024 Posted April 22, 2024 Did find this though Honeywell Galaxy Rs 232 Connection Help - Introduce Yourself - Security Installer Community (thesecurityinstaller.co.uk) Quote
