Hi there
Sorry for my ignorance.
Can you tell me the difference between Honeywells ADE Accenta Mini Gen 4
with LCd keypad (8SP399A) and
The Honeyell ADE Accentta Poly Gen 4 with LCd Keypad (8SP411A) are they both
compatable with the Honeywell easyset controller
Kindest Regards and many thanks
Terry
Hi: I take it that you refer to the ADE Simple set reader, which is a Prox Tag system, if this is the case then as long as both Panels have a Keyswitch Facility for setting / unsetting then yes they are compatible.
Regards: Andy @ Amman Security.
Actually the simple set has 2 modes of operation
As specialist says where the outputs are wired into inputs to keyswitch arm etc, but they can also connect on the keypad line of the accenta / optima to allow full interraction without using inputs.
Support
