Podbrook Posted May 15, 2021 Posted May 15, 2021 Just reduced the volume on the keypad by pressing and holding D then typing code 2000 to get into keypad menu. Adjusted to volume 1 and the sound reduce as this was completed. Pressed A to save and exit but keypad is frozen and no button works now. I can’t reset using numbers, proximity tag, key fob or app as access is denied. Need advice as to get the alarm working again. Help please. Quote
Secware_Tech6 Posted May 16, 2021 Posted May 16, 2021 It looks like you changed the keypad address Quote
