Will Posted August 11, 2020 Posted August 11, 2020 Hi All, I have an old Siemens IC60 panel with 3 wired keypads, 3 wired sensors, plus some wireless stuff (Sensors, Smoke detectors, keyfobs etc..) I also have some z-wave and 433 home automation stuff running under vera edge and domoticz. I am looking to upgrade this to something more modern. My main requirements: - IP connectivity so I can monitor remotely - 3 wired keypads - Images / video on movement when armed - but want to avoid standard IP WIFI cameras inside my home. - Easier to arm / disarm (RFID, keyfobs, Bluetooth proximity etc) - Ability to view video / images without a phone - If I am in bed, and the alarm triggers, I want to see what triggered the system before I go and look - As much wired as possible (I only use wireless if wired is too ugly) - Pet safe - Added bonus - Control my lights etc - Budget ~£1k I am considering the Honeywell flex with a touchcentre for the visualisation of images / videos I was also looking at Simplisafe and Jablotron from the US - but these seem to be mostly wireless. Does anyone have any other suggestions or recommendations? Thanks in advance Will Quote
Secware_Tech6 Posted August 11, 2020 Posted August 11, 2020 Hi Will The eaton stuff might be a good place to look https://www.eaton.com/gb/en-gb/products/safety-security-emergency-communications/security-intruder-alarm-systems/secureconnect/build-a-system.html also the new siemens (now vanderbilt) has most of what you want. There is also a an mqtt broker for that panel There is a member on here that has an mqtt broker for the galaxy range using virtual rios etc. Id avoid simplisafe its not a pro system, like yale etc. There are tonnes of vids on you tube on how to get around the security of these diy type panels Quote
