Which wired alarm uses a 433mhz wireless remote key-fob.
RichardE
Good afternoon,
Can you help me please.
We are building a garage at present and want to use a wired alarm (we normally use the Pyronix euro mini) but we also want a remote wireless key fob that uses the 433mhz frequency so that we can add this new alarm onto the existing key fob that controls the auto gates, outside lights and the garage door.
The Pyronix KEYFOB-WE is on the 868mhz frequency as are most of the main manufacturers key fobs.
Is there either a good company making a wired system with a 433mhz fob available or a 433mhz wireless alarm expander/key fob that can be added to a Pyronix alarm?
(I’m aware that the 433mhz frequency may not be quite as secure but this is a garage and it will not have a Ferrari in it.)
Any help will be appreciated.
Thank you, Richard
the frequency isnt the only thing to be concerned about. They also use their own protocol so a visonic 868 peripheral wont work on a pyronix etc.
Assuming you want to use the same fob to open the garage doors and also control the alarm your going to need something with flexibility and RF options. Nothing a euro mini is capable of.
I would recommend using the alarm to control the door rather than the door control the alarm due to the security aspect. ie you read about 'people' driving round with 433 transmitters to see if any doors open etc. That cant happen with an alarm fob
Id look at either app control, if a registered installer the HKC can do this with either keyfob or app. If not then id look at honeywell dimension or vanderbilt spc
Or put a keypad on the euro mini in the garage
Thank you very much for clearing that up.
We will keep the alarm key fob separate on your above advice.
Can the UR2-WE Two-way Wireless Universal Receiver and the KEYFOB-WE two-way wireless keyfob be utilised on a euro mini?
If not then please recommend the appropriate (ideally wired) control panel.
Thank you, Richard
Thank you.
We do require prox key pad and it has to work with https://www.securitywarehouse.co.uk/catalog/intruder-alarm-c-36/intruder-alarm-ancillaries-c-36_46/ade-honeywell-easy-set-fobs-tags-5pk-p-2097.html as we have many alarms that already use that type of fob/tag, can you kindly confirm that the galaxy works with that?
Also it appears that the Galaxy key pad with prox is £168.41. That is top money for a key pad (we need 2!)
Do you have any alternative suggestions? Perhaps a control panel that is setup already with a remote key fob (incidentally we only require the following to be wired, 2 pir sensors, 2 key pads, an internal sounder and an exterior bell box, if that helps?). Must be able to use the above style prox key fob/tag.
Thank you, Richard
no they are for the easyset only the galaxy fobs are
https://www.securitywarehouse.co.uk/catalog/intruder-alarm-c-36/intruder-alarm-ancillaries-c-36_46/honeywell-galaxy-ask-keyprox-proximity-fob-p-1460.html
a keyprox keypad (mk7 is the cheaper one) is https://www.securitywarehouse.co.uk/catalog/intruder-alarm-c-36/security-control-panels-c-36_102/control-panels-all-c-36_102_41/microtech-galaxy-mk7-keyprox-lcd-keypad-p-699.html
and is currently £93.98
the flex gives you some programming flexability but maybe a kit overkill. The issue you have is wanting hybrid it puts you into a different range of product.
https://www.securitywarehouse.co.uk/catalog/intruder-alarm-c-36/security-control-panels-c-36_102/1124-input-zone-medium-c-36_102_103/honeywell-galaxy-flex-20-uk-panel-mk7-keyprox-p-3972.html
might be a lower cost way of getting a panel and keypad.
The panels with built in rf recievers are mainly wireless only
Thank you for your help but as stated we very much want to use the more universal prox key tag that the euro minis etc use (we have more than 30 alarms that already use that key tag).
That being the case I want to use the Pyronix Enforcer as it uses that key tag and comes with a wireless remote key fob, this panel (whilst mainly set up for wireless) has 2 wired inputs that we could use for 2 PIR sensors we require.
I have 3 last questions;
1. Am I correct that there are 2 wired key pad inputs so that we could use a pair of https://www.securitywarehouse.co.uk/catalog/intruder-alarm-c-36/security-control-panels-c-36_102/lcd-remote-keypads-c-36_102_107/castle-care-tech-euro-lcd-rkp-built-in-prox-reader-p-2910.html
2. Is there a wired output for a bell box? https://www.bentleysecurity.com/product/classical-sounder/ is our preference.
3. If we wanted to add a further sensor or door contact can we use this https://www.pyronix.com/uk/products/euro-zem8-2 if not please let us know which product does this.
Your assistance is very much appreciated.
37 minutes ago, RichardE said:
Yes
yes but you need an input for the tamper
yes you need a wired zem that will sit on the data bus
Id have to check but you need the I/O board in the enforcer to expose these connections
Thank you very much.
Just to clarify
 Can you tell me how we get an input for the tamper?
Are you suggesting that we will require a wired zem to “expose these connections”?
Can Security Warehouse supply all of these items?
Please kindly confirm.
