Secware Posted February 21, 2018 Posted February 21, 2018 I'm having some problems in getting the CQR SC517 to work with the Premier Elite 48 panel.5 contacts work as intended and they are setup the way that I cut T1,T2 and the red wires giving the correct restiance towards the Texecom (Double Pole / EOL), in Wintex they work perfectly.10 contacts do not work, gap is the same between the contact and the magnet 6-10 mm. The do not work, same resistors are cut. In Wintex they report tamper alarm.Any ideeas ? Quote
